Postby
Rolling Estonian »
https://forums.nicoclub.com/rolling-estonian-u93756.htmlThu Aug 07, 2008 11:37 am
I just did this on monday (sorry I didn't take pics). But I did it the same as others have done it (there are threads with pics).
From the battery go straight up to the firewallthen go across the car to the passengers sidebehind the glovebox there is a plastic plug (remove it)ran the wire through the hole, and to the door sillunder the door sill and to the trunk
Postby
rjdmmfl1 »
https://forums.nicoclub.com/rjdmmfl1-u77059.htmlThu Aug 07, 2008 1:22 pm
I drilled a hole through the firewall on the driver's side... whatever way you run it, just be sure to run your speaker wires/RCA's on the opposite side that you run your power wire.
