the converted wrote:
Actually you can. I haven't seen anyone actually do it in over 10 years, but you can.
Maybe we're thinking of something different, or they did some something different back in the day, but a true "bridge" of channels, sums two stereo channels into one mono channel.
As you can see in this picture (Yes it's a pro-amp because it's so much easier to see the gains on pro-amps vs car amps) only one gain is used, the other is at 0 (actually negative infinity), yet both channels show the same amount of output.
Thus, if properly bridged mono, it can't also simultaneously play stereo.
rsmithdrift wrote:And the 6x9's are 4-way speakers so I'm not worried about them getting the wrong frequency. They are made to handle 20hz to 20,000hz safely up to 400w.
While they may claim to be rated for 400w and they're full range speakers, it doesn't mean you can flood them with 400w at any frequency from 20-20khz. *more on this later*
rsmithdrift wrote:I'm worried about the woofer because I blew one up because I had the frequency set to 200hz and it burnt out the voice coil eventually, so I'm afraid not using LPF will burn out the new one.
Ok, your woofer will, by far, handle more power than your 6x9's. But anyway, since you don't think I know how to bridge an amp, I will think that you dont know how a speaker blows.
How speakers blow: Thermal failure or Mechanical failure.
Mechanical failure means the speaker's excursion reached beyond it's linear limits and one of many things happend, including, but not exclusively, a spider tearing, a spider or surround coming unglued, a voice coil former becoming damaged from bottoming, a VC former coming unglued from the cone, a cone destructing/bending.
Thermal failure, which is typically how companies rate the power handlings of their speakers, which may be higher than it's mechanical failure depending on enclosure and frequency played. It's a means of over heating a voice coil to the point it melts, burns, unwinds due to glue failure, or even burnt tinsel leads. On rare occasions, high heat over time will begin to demagnetize the speaker, reducing it's BL (look it up), causing it to perform at sub par levels, but I've yet to actually hear of that happening to anyone.
Why your 6x9's won't handle 400w. Mechanically, they're excursion limited in the bass region, which means they can thermally handle more power than what will damage them mechanically. If you start playing some bass heavy music they're forced to do the job that your subwoofer is already except they're not made for that, will wear out faster and run a higher risk of blowing. I would also bet, thermally, they can't handle 400w (pink noise, minimal crest) for more than a second.
At the same power level, for each octave you drop, excursion increases by 4x. If you want to see what that looks like, here's two of my 15's (in my house) dropping down, while my amp is still putting out the same amount of power.
http://www.youtube.com/watch?v=gz3s4jKqtTw
So let's say those 6x9's have an xmax of 6mm, which would be a bit generous. If at 150hz, you're mechanically limited to 150w, then at 75hz, you would be mechanically limited to 37.5w. If you still gave it it the 150w, you will pop that speaker.
For that example, I am just throwing out a starting point number (150hz and 150w), I'm also ignoring any BL (look it up) reductions due to increased excursion and Cms (look that up too) increases, again, due to increased excursion. I may not be a transducer engineer, but I've talked with a few and learned a little bit.
