Running a SE-R ECU and AFM
Top Speed Coupe
Car: Cars
Has anyone heard of runing a 91-94 SE-R ECU and Air Flow Meter? A freind told me to do it, so I did and it is great no more speed limit @ 122mph I get 137mph no prob. Ups the RPM Limiter. Made my engine run more Stoichiometric(between rich and lean if you done know i.e. PERFECT or close to it)'
Has anyone else triend this?
- Zak
I am Technoman
Car: ???
What year 240 are you using this ECU on ?
Are you talking about an US spec Sr20de ECU?
Top Speed Coupe
Car: Cars
Its a 91, but I am using a 96 motor, with 91 Harness and ECU. The SE-R ECU is from a 91-94 SE-R as well as the AFM
I am Technoman
Car: ???
Do you think it would be the same on an 95 an up KA harness?
How many os sensors are you using?
Top Speed Coupe
Car: Cars
I know it is different then the 95 Harness, I am using all the sensors the 91 uses. There are 2 or 3 not used like extra Emissions that the 96 motor uses and I had to use the 91 Distributor.
