NeedCAforS13 wrote:you can't really lower the boost... the wastegate is set to a 7 pound spring. you can raise it by bleeding off air and not opening the 7lb spring, but you can't lower it. just don't floor it and you don't get boost. I drive 90% of the time either in vaccum or at 0... boost eats gas:(
believe me, you won't have boost until 3k anyways, so just shift before then and you'll be fine. hell you can rev it as high as you want, as long as you aren't giving it lots of gas, you won't build boost!
Sean
doh...but what happens when I'm not keeping the stock turbo and say going for um...the disco potato?
Since with my plans I also want a quick spooling turbo (which gets good boost by 3500 rpm) :/ Well hmm..I don't want a laggy turbo that's forsure...
Would an external waste gate beable to allow lower boost levels? (going a little off topic, but still kinda on topic)What would be a recommended turbo for something like this, and say a car that'll make 330whp, but still be excellent for quick spool and autox (since autox needs good boost responce)
