Oh its gonna be a go...don't you worry about that. I might not even be the first.PapaSmurf2k3 wrote:I think it would work. "In theory", your voltage would'nt drop, but your amperage to each injector would. C'mon Brian, I thought you were the type to do it first/ ask questions later. If all els fails, it should be totally reversable.
Well that same thing could be said for any of the primary 4. That why I have a knock meter and alarm. Losing an injector anytime means bad things for that cylinder, with or without added injectors.Swedish Mike wrote:I would use bigger injectors instead, fragile to run 8 injectors. One gone and a melted piston.
True but 8 is twice the risk.WDRacing wrote:Oh its gonna be a go...don't you worry about that. I might not even be the first.
WD
if its on the same circuit the injector itself would have to completely fail 100% during boost for him to loose a piston...Swedish Mike wrote:
see thats what I was talking about!WDRacing wrote:I'm the guy who usually just does it to see what will happen
Haha, yeah, you have to risk some to win some!WDRacing wrote:You find out about me quick Mike, I do everything ALL the way . I'm the guy who usually just does it to see what will happen
