Running 18" 8.5 wheels all around
superuber
Question: Has anyone run the 8.5 width rims on the front? I have a G35x and would like wide rims all around.
biggie
Wouldn't think there would be an issue. As long as the tire doesn't hit the shock or doesn't rub during turning.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
You could try just one 18x8.5" and check for clearance. As long as it doesn't bump in to drive shafts or some other front driveline/suspension it would probably be functional. I wonder if Nissan had a reason for the narrower front shoes. It would make tire rotations and replacement easier. Raise your hand if you always wear out the rears well before the fronts. I do rotate about every 5k.
