alexf20c »
https://forums.nicoclub.com/alexf20c-u34818.html
Fri Dec 04, 2009 12:22 pm
you just wanna be cool like those trucks that drive with just their fog lights?
if you go into the relay box under the hood, you can hotwire the supply voltage going into the fog lamp relay (use a multimeter or wiring schematic to determine which wire to cut). it's currently connected to the headlamp circuit, which means it only gets power when the headlamps are on. if you run a jumper wire to ignition voltage, you can turn the fog lamps on whenever the key is ON. if you run the jumper wire to battery voltage, you can turn them on whenever you want, including when the key is OFF.
