2BN_S13 wrote:Now you see, this is news. I have been told that the bellhousing is actually longer than the S13's and that would lead me to believe now that the gear box is (A) shorter than the S13's or... (B) that the information you just said is untrue. I need another trip to the junk yard...
Nope, the bells are the same length. It's the rear section that's different in length.I'm using an S13 SR bellhousing (I'm running an SR20DE) on my S12 71C gearbox with my stock S12 drive shaft, no issues... The drive shaft is exactly where it was with my old CA20, and so is the shifter.
If I had used an S13 gearbox on my S12, I would have had to shorten the drive shaft by 10MM-14MM (or use an S13's drive shaft front section) and slot the shifter hole back a little.
