C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Apr 16, 2003 2:33 pm
no. Frame damage is actually not hard to repair. Put the car on a frame rack and the shop basically pulls in the opposite direction(s) of the movements the frame went through when the accident occurred. Any good frame guy should be able to pull it back to the original specs. Sometimes with even better tolerances than it was when it left the factory. Cars with heavy frame damage usually total because of the extent of frame repair needed. Frame labor is usually double that of regular body labor. But even then, if the car has a high enough value, then as long as it;s not damaged beyond repair(crushed, torn, sheared off) usually it can be repaired.
