Ruckus racing mount locations on 1J
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
305_rb
where do you mount them there are 6 holes?
thanks
leroiboy
Car: 1989 Nissan 240SX Coupe
on the side with the intake, you remove that garbage fuel line-feed setup and use those two holes that you removed the bolts to that bracket that held it on and the two holes to the left. the exhaust side should line up. hope this helps ya
Return to “Hybrids”
