chmercer wrote:you can fit thoes with stock rucas and a pull, usually rucas are used to remove camber, not add it, if you slam an s chassis you will usually end up with like 4+ degrees of rear camber
S13s don't have the Mega camber gain that S14s... neither do they have the mega toe gain.
tucking 17in tire on Stock links will give you about 3 Camber. and nearly half a degree of Total toe with the links maxed out for less camber.
Doing that on an S14 gets you Josh SPL "I'll just replace my tires every 200miles" aligment.
