elwesso wrote:What threads have you gone through, because I know I've gone through . having -2* degrees of static camber vs -.5* will not matter as far as tire wear concerns, so long as the TOE is set properly at the new ride height...
Actually, -2° of rear camber does affect tire wear substantially over -1.5°. While I agree toe is much more important, negative camber has to be addressed.
One need s to read Q45tech's posts about the consequences of lowering and the remedies involved. Then read Wes's post about his set up. There is no easy cheap way. Being cheap with suspension bits is not a good safety practice. When one visits SPL, one can see the care they take to design and manufacture their components. The owner is not some teenie guessing at what should work, but has a doctorate in physics from UT.
