Rubbing with Maxima Rims
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
jitu884
Hey guys,
I got a 02 Altima and I just put the 18inch 04 maxima rims with 245/45/18 tires, and im getting alot of rubbing.
Would you guys suggest to go to:
225/45/18 or 225/40/18
Does anybody have this setup?
Your help is needed!
Thanks!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Have you checked the difference in the offset between the 2 wheels?
You can use this site tocompare tire sizes:
http://www.miata.net/garage/tirecalc.html
acidjake75
Car: 05 DB Z
Im sitting on G35 18s with 225/45/18 all around... 40 Aspect ratio will work too..(thats on an 05 Altima Sedan)
When you turn do you rub in front? you may also look into rolling your fenders in the rear if you are looking for that "flush" look
Return to “3rd Generation Altima Sedan (2002-2006)”
