rubbing sound in reverse.
matchstyc
Car: bmx, cars, music
Whenever I put my car in reverse and start to back up it makes a groaning sound in the back. Sounds kinda like as if the tires are rubbing the wheel wells or somethng but there's no way this is happening on a stock suspension. It only makes this sound when in reverse going slow. Could it be bearings? Confused! And godamn is it embarrising when I'm parallel parking.
MrFox
It's usually the rear brake pads. When they get thin they vibrate against the rotor when going in reverse because they sit loose in the caliper and get rubbed the wrong way. The noise went away completely when I changed the rear pads.
GroundZero
yeah it's your rear pads, my rx did the same until i did the brakes, when was the last time you did a brake job on your car?
bendychicken
Car: Racing, Pyrotechnics, Gardening(don't ask)
Mine is doing the same thing! I'm gonna go change the rear pads right now. I'll let ya know if it fixes it.
nolaws4evr
Car: cruisin tha streets of Huntsville, runnin down hondas, tryin to get money out of my insurance comp.
ive got the same problem and I know its b/c of the pads cuz I didnt change one b/c the caliper was stuck. oh well, as soon as it comes out the shop Ill fix it.
matchstyc
Hrm, I'll have to check that out and see. But if I remember right. They started doing that right after I got them replaced though. Maybe it's just the type of pads. I can't remember what they are. They're about a year old now. Lemme know if your's stop doing that when you replace em' Bendychicken!Also, anyone have any reccomendations for good brake pads that don't turn my 17's black in the rain. God those wheels are a ***** to clean!
bendychicken
It worked! here's what I did:I cleaned and greased all the sliding surfaces of the clips that hold the pads. cleaned and greased the studs that the caliper floats on. then I replaced the pads.worked like a charm.
bendychicken
Remember! turn the caliper pistons to make them go in. that's what those grooves are for. don't push them in.
