rubberized undercoat
LOVERboy
Car: 1997 240sx se KAT
i got bored today and have nothing to do so I decided to go strip my car down. now after striping it down i went to Autozone and brought myself 5 cans of 3M rubberized undercoat. then i came back home and decide to be lazy to strip the stock sound deadening off so is it ok if I just spray the 3M over the stock sound deadening? would it be better to not be lazy and take the stock one out first????
thxs guys
-sUNNY D.=
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
dont half *** it, scrape off the old, spray on the new..
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
LOVERboy wrote:i got bored today and have nothing to do so I decided to go strip my car down. now after striping it down i went to Autozone and brought myself 5 cans of 3M rubberized undercoat. then i came back home and decide to be lazy to strip the stock sound deadening off so is it ok if I just spray the 3M over the stock sound deadening? would it be better to not be lazy and take the stock one out first????
thxs guys
-sUNNY D.=
im doing the same, you should take the sound deadening off, even tho its a *****. I feel you on the lazy assness, but its gotta be done.
LOVERboy
i only did the driver side ........ ran out of dry ice. its 4.40 am right now and i just finish putting everything back together... i would of do the passenger side if i didnt ran out of dry ice.... and i also need to use the car tomorrow (well its today now). i promised my gf to take her out sooo.... sigh so effin tired...
Dittoz7
Car: 1997 2f0WtY SE!
That Would Make No Sense...
nightsauce
At least you're using dry ice...im out there with the good ol steel wool.
MastaYu
Car: 92 Nissan 240SX SE HB
steel wool wow thats sounds like a *****
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
Probably just my car but....I never used the dry ice. I went out on a warm(75-80*) day and took a putty knife and just peeled all the sound deadening out. It literally just came out in huge sheets. There were a couple spots where it left residue, so i just blasted it with brake cleaner and wiped it off.
Make sure once you get the old out, rought up the paint a little so the undercoat sticks well.
240-slide-ride
Car: pignose
when i took it off my buddies svo i used the wedge end on a crow bar it took me like no time and didnt scratch the paint underneath surprisingly.
TheAmazingBlaze
Take it for somebody that has a bodyshop...this is what your looking for...Trust me
http://buy1.snapon.com/catalog...talog
OR at half the price
http://www.harborfreight.com/c...95924
These things are great, it's like a wirer brush on a drill but 10x better and faster.
Only one warning, well maybe two...First safety when your using these wear gloves, googles, ect.
second and most important, when you use them because of the way they spin they leave super fine almost chips, i mean you can barely see them. The problem is that if you use this tool and make a bare metal area, you have to seal/prime fairly quikly within a day should work. If you don't micro rust will start in those tiny little specs...and trust thats a pain in the A$$
Good luck
TheAmazingBlaze
wow i mis spelled goggles lol
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
I didnt have to work to hard to get my deadner out. I used a hammer and a putty knife and it came right up.
gregfarz78
Car: 04 Honda S2000
97 Nissan Hardbody King Cab 4x4
09 Nissan Altima Coupe 3.5L
I used that 3m undercoating after I stripped all the interior, it works good my only complaint is it scratches easily but I don't really care b/c carpet and interior will be covering it anyway I used it mainly to deaden some noise
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
would primer work inside the car as the final outcome?
like after sound dead spray primer and leave it alone and reinstall interior?
ZOMG.SR20
Car: 1990 s13
umm isnt truck bed liner the same thing jw
also this looks like a great deal
http://cgi.ebay.com/24-Cans-Ne...l1318
m tr4nch
Car: RS13, Z31, P11
gregfarz78 wrote:it works good my only complaint is it scratches easily
it scratches easily? like scratches off? i got some 3m rubberized undercoating which i was planning to use underneath my car. i don't want rocks and stuff to scratch it off...
moulton712
Car: coupe, hatch, both s13s
dry ice is the best and lazyest way to do it. that happens is it makes the metal and the sound deadining contract differently, this difference makes the two layers seperate. meaning just take a hammer and crack the deadining. it works alot better on a hot day.
s13gebala wrote:would primer work inside the car as the final outcome?
regular primer holds in moisture and mosture turns into rust.
dont worry about it comming off, it's not as bad as it sounds. he's really taking about the way it looks. it looks mint going on but after u put something on it, there will be marks left.
gregfarz78
Car: 04 Honda S2000
Did you buy this stuff?
It came out good on the interior but I don't think it would hold up to abuse on the undercarriage of the car I'm going to get some truck bed liner and brush it on under the car.
