Rubber washers under the bolts for the valvecovers, is there a USDM interchange?
240z4u
Car: '95 Nissan 240SX
Guys, my valve covers insist on leaking. The rubber washers under the screws are smashed flat and not providing good clamping for the valve covers. The gaskets are all but new and not smooshed down too much.
Are there any usdm crosses for this part? Or should I just go snag bolts without shoulders?
Thanks guys - Evan
gawdzilla
Car: none
it's usdm..13268-58s01~$1.65 a piece
Or, take one to Ace Hardware and buy something similar for a nickel apiece.
Carl H
ca18de valve cover grommets, effin expensive tho i spent like 40$ on new ones for my car...and that was at parts cost!
Shocker
Car: 89 240sxHB rb26/30
Carl H wrote:ca18de valve cover grommets, effin expensive tho i spent like 40$ on new ones for my car...and that was at parts cost!
your better off just buying the gasket rebuild kit.. it comes with them.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Really????I had two gasket kits and they didn't come with it.
The only thing it had were the two valve cover gaskets themselves.I don't think It even cam with the Half moon cam seals either.I think I bought Z ones.
Shocker
yeah I got all of them, I think theres even enough for my front timing cover's. Mine came with cam seals as well.. lol, sounds your got a half empty box.
RB_Dreamin
nah, the rb25 kit doesn't come with them.
no valve cover washers or timing cover washers
Sil240
Shocker wrote:yeah I got all of them, I think theres even enough for my front timing cover's. Mine came with cam seals as well.. lol, sounds your got a half empty box.
Aww man that sucks....I had two Brand New Nissan Gasket kits.I need those little things.Bastards!!!!
mello88
Car: s13
RB_Dreamin wrote:nah, the rb25 kit doesn't come with them.
Yeah my RB20 gasket set didn't come with them either, and mine are toast.
Courtesy sells them for $1.83 each. How many are there, 10 on each cover? So $50 shipped for some little rubber grommets =/ I think I'll try to find some thick o-rings or something cheaper locally.
240z4u
Turns out I am not the only guy with this problem haha. Ill let you guys know what I find!
Evan
integra7
Car: 1995 Nissan 240sx
gawdzilla wrote:it's usdm..13268-58s01~$1.65 a piece
gawdzilla gave you guys right correct usdm part number. you guys can't spare $33 + shipping??
240z4u
I have a road trip coming up in a hurry, need something before then. If my dealer has them (or can get them quick enough) ill prob get the oem ones.
Evan
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
My motor was missing quite a few of those little bastards too. I just took one of them down to the local import junkyard and the guy there led me into a room full of junked heads and said "Have at it." I just matched up the grommet size to some random ones I found at the junkyard and slipped those ****ers in my pocket and walked out... Ultimate discount and I have yet to see any signs of a leak!
** I do not condone stealing, BTW, but $33 for some grommets is ricockulous.**
