Rubber shift boots
deezlins
Car: 95 240SX SE
I've done search after search after search and read numerous transmission swap guides, short shifter installs, anything to do with these boots and cant find the answer. I'm about to order new rubber shift boots for my S14. The lowest one on the transmission is torn that looks like this http://www.frsport.com/Genuine....html
and the top of this one on my car isn't tight around the shifter rod, I guess its worn out and become loose, i can wiggle it around and smoke is getting into the car from it so I assume it needs replacing too ( I assume it should be tight around the rod sealing off the cabin). Part # 74960-35f00 according to pic on ebay of one being sold http://www.frsport.com/Genuine....html
So what is this boot? Is it one my car is missing? Does it go under the one in the pic above? Is it on a different model or something? Do I need it too? Part # 74967-35F00 according to pic on Enjukuracing.comhttp://www.frsport.com/Genuine....html http://enjukuracing.com/lower-....html
Any help is greatly appreciated, thanks
Modified by deezlins at 4:47 PM 11/7/2008
Modified by deezlins at 4:49 PM 11/7/2008
PorkChopExpress
Car: rb kouki
the bottom goes under the top one. zip tie the boot to the shifter.
deezlins
Car: 95 240SX SE
So I am supposed to have all 3 of those?Everything I've read has just mentioned taking off the rubber shift boot, then the boot on the transmission, but no mention of that flatter boot under the other one.
scottydog
Car: 1992 240sx
Use the first two.
