Rubber deal in carb?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
seven-20
Car: 720 shortbox 2wd
Found a rubber piece in my carb. Threw it away cause i though it had just fell in there at some point. Now my truck has an insane high idle cause the butterfly is always open. Anyone know what im talking about? What is it called and where to get one?
PEZi
to be honest i can't really think of anything... do you know where it was located before hand?
seven-20
It was just laying inside the carb. If it does not sound familiar,than it was probably just dropped in by the previous owner. I thought it may have been there to close the butterfly when off throttle but i guess not. So i guess i just have to figure out why my idle is high. The carb does not fully close as you can see in the second pick.
PEZi
second pic looks to be normal to me though... mine never closed passed that
seven-20
Yeah it ran fine for ever then all a sudden i went to put it in nuetral and rpm's shot up. Seems like it is getting to much fuel!
PEZi
well... start with the usual.... vac lines and such
Aven
Car: 84 720 Kingcab
If you depress the gas petal all the way down when the engine is off, your choke should close completely. That worked for me when I was having issues. I hit the cable links with cleaner and worked them a bit too. Now that I have the vac lines all straightened out it seems to be running fine.
seven-20
Aven wrote:If you depress the gas petal all the way down when the engine is off, your choke should close completely. That worked for me when I was having issues. I hit the cable links with cleaner and worked them a bit too. Now that I have the vac lines all straightened out it seems to be running fine.
Well i will go over everything mon-tues and update the thread :bigthumb:
seven-20
Seems fine now. I depressed the throttle all the way down and that closed the butterfly. Also found a small gap on the air filter cover. Could have been that. Thanks for the help :woot:
PEZi
good stuff man!
Aven
Car: 84 720 Kingcab
:dblthumb:
jdamion
Car: 1980 Datsun Pickup
dont forget some wd-40 on the linkage! can be stiff sometimes, i had mine stick wide open.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
jdamion wrote:dont forget some wd-40 on the linkage! can be stiff sometimes, i had mine stick wide open.
Yeah. The WD-40 works better and longer than engine oil.
Return to “Datsun 720”
