kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Mon Jul 26, 2010 9:50 am
Those rubber bumpers are actually designed to screw in, and it's this threaded design that allows you to adjust the hood. Early on my '08 Rogue had a hood rattle issue when hitting bumps, and all it took to correct the problem was to unscrew the rubber bumpers a couple turns to compress the hood and the rattling was gone.
When you turn mine, they are quite tight and I'm sure there is no way they could pull straight out considering they are threaded, so the only way to remove them is to turn counterclockwise.
Perhaps yours are defective, the dealer should inspect and provide a solution, as these are very important components and they should stay securely in place.
