Rt . Rear Tie Rod Rolls Out
automate
Car: 95 J30, 53 MG, 65 Imperial,
HI There.. I have searched the threads and cant seem to find anything on this problem..I have a 94 Q45t and the right rear tie rod rolls out of the rear cylinder assembly on its own.. The right rear wheel makes its own turn by then... I have screwd it back on two occasions .I am worried if this happens at high speeds causing a serious accident. . Is there some way to lock it in there? Thank you for any response....
Red coupe
Car: 92 Nissan 240sx Coupe
do you mean the hicas on your q is steering randomly?maybe you should try the Q45 section?
