RSR or Tein
Spec-R
I have a choise between either RS*R Heavy duty race springs or Tein type-s, i was wondering which one would have the handeling advantage. i really dont care how rigid the ride will be.
dr!ft
Car: 1988 Isuzu Trooper II, wish it was a 240...
Well, the RS*R Race springs are 5kg/f and 4.2kg/r and the Tein S-Techs are 3.8kg/f and 3.5kg/r, so it would seem that the RS*R's would have an advantage over handling. Also, they both lower the car about the same (around 1.4"-F and 1.0"-R)
Nismo_Freak
Car: 89 Nissan 240SX
RS*R but make sure to back up the springs with some good shocks/struts.
Exar-Kun
Car: 2005 350Z
yeah, RS*R will have the better transitional stability(slalom) but you'll need a really nice damper to go with it, the AGX may or may not hold up...if it does, you'd have to have it set pretty stiff to cope with that spring rate.-chet
Spec-R
so your saying the KYB AGX wont hold up with the RS*R?? they were gonna be my choise, so what other struts would do the job?
dr!ft
Well, what about the GAB shocks? Haven't used 'em, but would like to now if they could work with the RS*R's larger spring rate...
Nismo_Freak
GAB would be a better choice due to their purposely built-in short stroke.
dr!ft
Now which GAB shocks do you guys think would be best?-Super HP (adj) - $429/f and $295/r-Gymkhana (adj rear only) - $328/f and $295/r-Super R (adj) - $447/f and $375/r-Super Stroke - $500/f (<---:eek: ) and $313/r
I'm not all that familiar with the GAB shocks, so info would help. Also, I just searched really quick and found these prices off CyberAuto...
http://www.cyberauto.com/index.php/Nissan240SX.txt
Anyone know of cheaper prices? These things are damn expensive...
Nismo_Freak
Super Stroke
dr!ft
Damn, the more expensive ones. Are the Super Strokes adj as well?
Spec-R
man those GAB's are expensive, might as well by a Tein coilovers for that. what other shock could do the trick? cuase i might as well just save up for He's
