Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Wed Feb 25, 2004 11:30 am
All right. Now that I finally got the swap done this weekend (special thanks to Fiznat for his excellent DIY article) here are some photos and a preliminary review of what the suspension is like.
First, here's a photo of what it looked like before:
...and after:
I know. Hard to tell from these amateur photos. But the drop is just about perfect for my tastes - right about 1.25" in the front and 1.5" in the rear. Not too low, not too high.
Driver's side shot: (you can see the drop better)
Shot of rear wheel gap/spring (you can just see the logo)
So looks-wise, I love it. But how does it feel I hear you asking? Well, it's kind of early to tell since the springs and struts usually take a couple hundred miles to seat themselves in. My early impressions are as follows:
- Ride is way bouncier - not necessarily bumpier - if that makes any sense. On a road that's been rippled and deformed by heavy trucks, the 240 will bounce and jitter like a dancer in an Outkast video. That's both good and bad, good because you can really feel every imperfection in the road, bad because NJ has very imperfect roads and you will be constantly annoyed by this fact.
- Handling is far superior to the OEM setup, there's little body roll in hard cornering, no sense of floating at all; the car is very flat and predictable. Feedback is very, very good.
- There's been concern in past threads about the ability of the AGX to hold up to stiff rates like the Race Springs (5.0/4.2). So far I don't see or feel any evidence the shocks are being overly stressed. The ride is pretty stiff but not harsh. I'm currently using a 2/4 damper setting and will try out some others as time permits.
- Installation was pretty easy, took about 4.5 hours, although it should be noted my friend and I were goofing off a considerable amount. You could probably get it done in 3 if you're focused.
- I just took the car for an alignment at NTB, now it feels like something is loose/clanking from the driver's side front wheel area. I'm hoping it's just my imagination and I don't have to unleash whoop-*** later on. Or maybe just the new components settling in...yeah...that must be it. I hope. Anyway, I didn't have any problems getting the alignment back in factory specs without the use of camber plates/PBM mounts.
- Made an unpleasant discovery during this process: Thanks to a evidently retarded exhaust installer, my rear tie rod on the driver's side appears to be bent, as the exhaust pipe has been forced against it. So now I am looking at replacing the rear tie rods AND fixing the goddamned exhaust. Oh what fun it is! It never ends, does it.
Rant over - here's the info, hope you enjoy, PEACE. :peace
