RS*R Drop/Stance Question
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
I have the KYB AGX and RS*R Down spring combo and I wanted to know if the stance on my car is normal since the front sits lower than the rear by about .7 inches. I know the springs are supposed to drop the height by 1.6 in the front and 1.2 in the rear. I bought these used from eBay for an awesome price last year. Whenever I see lowered 240's online, most have coilovers, where you can adjust the height, or have spring/shock combos where the front/rear height is equal. When you look at the car from a distance you can see that the bottom of the car below the door is not parallel with the ground. S-tech's are a drop of 1.5 up front and 1.2 in the rear. I know you need pics and I will once I figure out how to.
onosqv
Car: '92 240sx Vert
yes, it's normal. all the #'s published are estimates - actual results may vary.
