FarFetched »
https://forums.nicoclub.com/farfetched-u25415.html
Wed May 25, 2005 6:42 am
Thanks for great insight!I did compress chk and vacuum check on engine. I haven done power bllance test yet. Compressinon within specs ~170-180 PSI Vaxcuum 18.5 steady as rock!Actually what happens is after a good drive (2-3 hours of ddrive) I stop engine, then restat (up to 30min after) and it starts to stumble in D or R and then stumbling slowly goes away! If I race the engine a bit "stumbling" goes away. It might comback later. I think I set IACV to 3 turns. I watch tach when it happens and notice when "stumble" occures RPMs don't come back to normal. Example, it idles at ~550 in D and when "stumble" occures it drops to (and below) 500 and stays there!All that doesn't affect performance at all. Spark plugs, KS, MAF are NEW. Cleaned TB, IACV as much as I could. It is just annoying! Thanks!
