RPMs drop and lights dim when braking and stopped
Dbass240
Car: 1993 240sx base coupe
So when im braking, especially at a significant speed, coming to a stop, my lights dim and RPMs drop about 2-3, sometimes 4-5 hundred. when i lift my foot off the brake it returns to normal idle...I changed the battery ground, it helped a tiny bit, the radio doesnt reset anymore...Im thinking bad brake light ground? or just old alternator? any input?
nismoracingsx
Car: 1993 White 240sx Coupe
checked for a vaccuum leak in your brake booster hose right?
Dbass240
i have not done that, would this account for the lights and rpms to drop?
NICONick
Car: 1993 S13
Dbass240 wrote:i have not done that, would this account for the lights and rpms to drop?
If your RPMs drop, naturally your electronics will dim somewhat. I don't know if this is your prob but I had a similiar prob. It would almost stall when stopping at a stop sign or red light. Cleaned my IACV and I was good to go. Try it!
nismoracingsx
lights can/will dim when the car threatens to stall. Anytime i'm playin' in the 240 and if I'm not paying attention and it almost stalls, the lights will dim.
Vacuum lines leaking can lead to s*** idle and brake booster line is much bigger than most, and the booster is actuated when you press the brake, so i'd start there, it's a 2.00 fix and easy to check.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I would think vacuum or a regulation problem. Check the booster and vacuum lines for leaks, maybe gave the alt tested.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Dbass240
Thank you guys for the help, I am changing my brakes this weekend, so i will do this as well! that sounds like exactly the problem
angrypenguin182
Car: 91' Nissan 240sx
Keep us posted, I'm having a very similar issue lol
