I have been working on my daughter's Maxima XE with a 3.0L V6. The problem we're experiencing related to engine idle. With the engine warmed up, if you bring the rpm up to ~ 1600 (in park) the engine rpm will surge up and down continuously until you either increase rpm out of the 1600 range or let it fall back below 1600. There are no engine codes. I have removed, cleaned and tested the IAV valve (all seems well with it) and replaced the TPS just to make sure it didn't have a dead spot in it but the problem remains. Any ideas anyone?
I was just out for a little drive again and noticed that in park from idle when you depress the gas pedal very slowly there is no smooth acceleration up to the 1600 rpm area. I goes from ~750 to maybe ~900 and then goes right up from there to 1600 without me depressing the pedal further. Then the surging starts and does not stop until you force the accelerator to the point where you reach about 3000 rpm.
