RPM's
justin56303
Car: 2007 Nissan Versa S Hatchback
My RPM's drop at around 3000rpms;55-60mph with the O/D button pushed.
Modified by justin56303 at 1:30 AM 1/17/2008
my_new_v
Car: 2008 Toyota Tacoma X-Runner
Need some more info, what exactly is going on? I tried reading it over and over but cant see what your trying to say lol. Maybe its just me.
biggie
my_new_v wrote:Need some more info, what exactly is going on? I tried reading it over and over but cant see what your trying to say lol. Maybe its just me.
Its not just you.
my_new_v
Whew! lol
Showcase
Car: 2007 Sentra 2.0S
is ur o/d off? then thats ur problem, i think it uses the transmission to slow the car down. like engine breaking.
my_new_v
He said it was pushed in so o/d is on. :P
Showcase
When i push the button, mine says o/d off on the gauge cluster. ???????maybe im just reading it wrong?
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
No, you're reading it correctly. The normal situation is Overdrive On, so that when you are at a high speed the engine can run at lower rpm. When you push the button it turns Overdrive Off, which is what the light shows. The engine will run at higher rpm.
Normally I use it when I'm starting from a stop and want better acceleration, or when I'm going slowly up a grade when I don't want the transmission "shifting" to a higher gear range.
