j1stande wrote:I would say split the max hp rpm and max torque rpm.....in other words
about 5,000rpm
best of both worlds
You should be shifting at the point at which the curve for the gear you are in crosses the curve for the next gear up. It's hard to see in the diagram Q45tech posted, but it was more to just give you an idea of what he meant. Shifting at 5000 RPM would be less than ideal if you're looking for the best acceleration. If you look at the graph, it shows 1st gear would probably put you at redline for a shift point. 2nd is slightly less. 3rd less is slightly less than 2nd. Of course this varies from car to car as different motors have different HP curves and different gear ratios so you would need to get your motor dyno'd or find one for the same motor(and mods) and essentially do the math or graph each gear scaled to your vehicle speed to determine where each curve crosses the next.
Splitting HP and Tq peak RPM's isn't going to be the best solution. Torque peak represents the point at which peak acceleration will occur for a given gear. The peak HP is the point at which the motor can most effectively multiply torque to the wheels. Generally, most motors will accelerate the fastest by keeping the motor at least above the torque peak to a point somewhere past peak HP. Most trannies will drop RPM's well below peak Torque if you shifted midway between peak torque and peak HP which would make you slower than you should be. Understanding that trannies are no more than torque multipliers and lower gears multiply torque more, the key to acceleration is to use the lowest gear possible until the point at which the next gear would provide more torque.
