Send some more time reading and learning about electrical systems and the q45. The time and money you will save is worth it.Noobius wrote:It Turns out that that car doesn't have a distributor cap like most cars, that it all runs on alternator, and so... The electronics in the MAF sensor have failed, And all the Electronics stedily fail, leading to an eventual stall of the car, The Q45 Cannot run without the alternator for very long unless you manage to keep the rpms up, and even then, the ECU fails also, and you cannot rev it correctly. haha, it was funny what happened, now it is anyways, but not back then.I thought it was dead forever..
Lucky for me I've replaced my MAF and alternator both new from the dealer. I'm curious what upgraded alternator you suggest to buy?Noobius wrote: Get a high output alternator as a replacement, because you always want to go a grade up, and never a grade down from stock.
Wow I never thought anyone paid attention to that link that too a while to put together. That really couldn't be done without Brian's AKA Maxnix And Q45tech help and NICO of course.ShortSeason wrote:From the TSB the G50 requires a Group 27, 675 CCA Batt. Higher than any other Inifiniti ever built to date.
If link below does not work... see Paul Wall signature with links to docs. Thanks Paul
https://docs.google.com/leaf?i...ex=24
Indeed I would buy another Q45 rather than destroy a Q45t especially from what I have heard from Q45Tech, That they do not cost much more to maintain than a base Q45 unless abused/neglected.Noobius wrote:And the daunting elimination of the Hicas, and a power steering pump replacement when I get to it. Maybe I should just buy another q45 I thinks....
Happy to hear that you resolved your issue. When my alternator failed, I looked at many options and very quickly realized after reading in here that genuine oem was the way to go. It cost me more but I at least I didn't have to do the job twice which was the case with quite a few people and I was up and going immediately.Noobius wrote:Thanks q45 tech, even though my initial diagnosis was correct, I made a mistake with the installation of the new alternator, and i killed it, It was not a high output alternator to begin with, just a refurbished one. so, I bought a refurb alternator from ebay, put it in correctly this time, and it has worked like a beauty ever since,
Don't think that any other Q45 is immune to repairs and service. They all require work. If the previous owner didn't do it, then chances are very likely it will be you who will. There hasn't been a day since I owned my car that I wasn't planning the next repair or service. I'm forever planning the next thing. No one said it would be easy to keep upNoobius wrote: Now, my challenge is, Fuel injectors, Spark plugs, and rack and pinions, and the daunting elimination of the Hicas, and a power steering pump replacement when I get to it. Maybe I should just buy another q45 I thinks....
