EOrdonez3229 »
https://forums.nicoclub.com/eordonez3229-u89932.html
Tue Jul 08, 2008 9:31 pm
No, that is not normal. The only way that would be normal is it you were red lining the gear, but you have an automatic and in your 2005 you shift at just about 60mph (on average). It may be that you have a transmission that is outputting a higher PSI (energy measurement). PSI basically means how hard your transmission is working, how much effort it is putting forth. Or, you could be in a different gear (the shifter is not set to "D"). I would monitor the issue and if it continues or even fluctuates in its occurences, I would consult the dealer.
Let me know how it works out. Good luck.
