rpm problem
JF240
Hi,I have a 1995 240sx s14, with 226000km. The problem I have is that the rpm is not working since 2 years. he only idling between the 0 to 500rpm and sometime it only stays to 0. But 2 weeks ago it was really cold outside like -20 and I started the car and the damn rpm worked!!! but for only 5 seconds and it return to 0 . I dont know if it come from the tachometer or from the sensor or a bad contact. If it is from the sensor can you tell me where it is on the S14.Thank you
Modified by JF240 at 3:14 PM 1/10/2007
JF240
bump
BlazeSilvias
Car: 02 Veilside Celica, 89 240sx, 92 kawasaki ninja 600
check the tach sensor wire in the engine bay. it may be disconnected or have a bad connection.
JF240
can you tell me where is located the tach sensor please, thank you,
JF240
nobody knows??
