RPM limits of a well built KA-T........
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
with stock HLA's???? I am considering a KA-T drag setup with a HX40 Pro Holset turbo and would like to know what the rev limit is for a KA with HLA's. A source for a good sheet metal intake would also be nice.
Best place for complete bottom end kit for the KA?
Modified by kentuckyslider at 4:00 PM 1/11/2009
Razi
Car: Moo
KAs don't have lifters.
AZ89two4Tsx
I want the coupe in your sig.
lrb_2000
Car: '91 Nissan KA-T hatch
lol.
why does it matter.. you can have the SR for revs, and KA for power.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
kentuckyslider wrote:with stock HLA's???? I am considering a KA-T drag setup with a HX40 Pro Holset turbo and would like to know what the rev limit is for a KA with HLA's. I source for a good sheet metal intake would also be nice.
I dont know what HLA is but, from reading the other post i am guessing a rocker of some sort. Ka has a cam over bucket design (same as CA and RB cylinder heads) so the head can take some rpm's with some mods. Ramon takes his built ka to 8K with cams, springs, and valves but, i heard he could take it to 8.5k if he wanted.
Jeff made 500+whp on a stock block ka with the hx40.
EDIT:Here is a link to Jeff's video
http://www.ka-t.org/forums/viewtopic.php?t=10982
Modified by nelson8708 at 5:39 AM 1/11/2009
kentuckyslider
Nice to know about the cam on bucket, never been into a KA. Just the SR. You think 7500-8000 is achievable then that will be fine. My JWT SR tune is rev limited at 7750 so the KA with a mild build on the head will rev just as high with 500-800rpm quicker spool and more TQ.
simmode1
Car: Red '95 S14
nelson8708 wrote: Ramon takes his built ka to 8K with cams, springs, and valves but, i heard he could take it to 8.5k if he wanted.
Thanks alot. Now my pants are wet and sticky. Where can I find more info on his build, please? I've have heard that making power and revving safely to 8k+ was supposed to be more difficult than that...
Edit: Nevermind. I found good info on the subject...
Modified by simmode1 at 1:31 PM 1/11/2009
nelson8708
here is a good thread on high revving ka-t. Hope its ok to link to another forum.
http://www.ka-t.org/forums/vie...07418
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
8200 on a fully balanced stock bottom end and stock valve train with 248/232 +.5 cam swap. Boosting 25 psi all year.
turbo2nr
Car: 97 240sx (kouki)
+1 8k is doable on a ka..
link has tons of info...
simmode1
Car: Red '95 S14
nelson8708 wrote:here is a good thread on high revving ka-t. Hope its ok to link to another forum.
Lol... thats the thread I read about a month ago that cast so much doubt on the subject to me. It just seems that most ppl seem to think it's not worth it and try to dissaude you from trying. However, if you could have a motor with power and torque as low as 3k rpm, all the way up to 8/8.5k without any really crazy motorwork, why not?
Cakesfab
nelson8708 wrote:Ramon takes his built ka to 8K with cams, springs, and valves but, i heard he could take it to 8.5k if he wanted.
Ramon's motor still has stock valves. It sees 7500-8000rpm often and i would estimate damn close to 700whp if not more.
Here are a couple of videos of his last races.
vs 500whp cobra, 650 on spray but claims not to be spraying. 240 was experiencing some igntion break up issues. http://www.youtube.com/watch?v=P7DDblmDfWs
vs low 600whp civic. New ignition setup and a little more boost. http://videos.streetfire.net/v...3.htm
This is still on a mild street tune. Car has yet to see a dyno.
kentuckyslider
Can someone give me just the basics of "Romon's" setup. Turbo, tune, injectors, etc.... Just trying to get an idea of what I'm getting into to have a 10 second KA-T. I know I'll be running a holset HX40 pro with a BEP .70 ar housing(flows 70lb/min). Should be plenty of turbo to put a KA well into the 10's. Currently going HX35 on my SR with a JWT rom tune and 72lb injectors. Should be 450whp at 20-25psi before I run out of fuel.
Cakesfab
Ramon's car is basically composed of a borg warner s372, custom intake and turbo manifolds made by me, built motor, standalone, and supporting fuel system. If you need more details, feel free to pm me.
turbo2nr
r@mon's car rocks! its one of the fastes ka's , and not alot of ppl know about it.
you Fl, people dont play around lol. cakefabs you do some nasty work when i have funds i might pm you to make me a intake mani!
Cakesfab
thanks
nelson8708
turbo2nr wrote:r@mon's car rocks! its one of the fastes ka's , and not alot of ppl know about it.
R@mon's car is by far the most bad *** ka around. The drag cars that set new records are cool but, that is just one nasty street car.
for angel's fab ability ......cant wait for death-rolla to hit the street / track
