rpm hesitation
WYT R1CE
I just finished up on my swap, car runs. everythings hooked up to my knowledge but its ahving some problems. the car starts and idles perfectly, but when you throttle it it revs only maybe 2k rpms and hits a hesitation and wont go hire. anyone have any suggestions on what it could be? i have a buddy coming to help set my timing on saturday with a gun.
one thing that i should point out is that i havent had the chance to weld the bung to the cold pipe to attach the hose that routes under the intake. im not sure if that would have this siggnificant of an affect but it might.. ??
float_6969
Have you pulled codes from the ECU yet? That is ALWAYS your first place to start when the car runs like crap.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
A bad maf/incorrect maf wiring will make the ECU cut ignition at 2000 rpms.
tyrannix
Car: go big or go home
set your timing, then pull your codes.
and that hose should only be affecting your idle, but if its not hooked up, did you plug it? if you didnt, then you should have a boost leak among other things
CJ
1via
I had that same problem. It was my maf. Replaced it and its good now.
WYT R1CE
i plugged that hose. once i do the timing tommorow ill check for codes, then ill check the maf hopefully that solves my problem.
thanks for everyones advice
