leper421 »
https://forums.nicoclub.com/leper421-u1481.html
Fri Apr 16, 2004 4:32 pm
If its anything like a KA, the engine speed comes from the crank angles sensor on the distributor, from there it goes to the ecu, then the ecu sends a signal to the tach. Check the wiring from the ecu to the tach. It could also be a bad gauge.
