BlindedSlide »
https://forums.nicoclub.com/blindedslide-u124543.html
Thu Feb 19, 2009 10:59 pm
i got a spray bottle with the stream setting on it, got some isoproyl alcohol (91%),
sprayed my maf sensor down (the inside wires that read the air),took out my 02 sensor and did the same thing, cleaned the contacts between the coolant ECU and gauge connections,
and now it doesn't fluctuate anymore, but, when coming to a stop it will drop a lil bit under 1000, like 900 rpms, and instantly go back to normal.....
maybe if i try cleaning it again a few more times,it will go away until something does fail.(keep in mind this is a temporary fix)
idk if this could help anyone,but i guess it had some positive effect without blowing anything up...
i took everything out and let it sit 1 hour to dry before using it again also.
if there are any other sensors i could clean with this method ...could someone give me a heads up?
