ser2102 »
https://forums.nicoclub.com/ser2102-u30301.html
Mon Jun 26, 2006 1:35 pm
yeah so here's idle problems 347862174 on this board.on my redtop i cleaned out the aav valve, intake mani was very clean near the head, and the injectors look brand new, thank you redline injector cleaner!however, the idle is set at 800 RPMS, but if i do ANYTHING to the car, it drops down to 500 and starts bogging, then goes back to 800. its not a huge deal, but if i come to a stop light, i push in the clutch and it drops. so here are the things that affect it...1) push in the brake pedal2) let off the clutch3) turn on headlamps4) turn the steering wheel
i have been told it could be a ground problem, and im starting to think so, due to the headlamps causing the bogging. anybody have the same experience?redtop s13
