rpm drops at 3k
mccune240
just swapped an s14 sr20det into my s14, and now the car idles horibble for a few seconds then idles fine but when i rev the motor.. at about 3k rpm it stops and drops back to a rough idle. One of the guys that helped out with the swap said i need a boost sensor or a charcoal canistor. i have no idea what he meant by boost sensor.
Vr6WantSr20det
if your car wont rev past 3krpm thats a pretty common problem with the Mass Air Flow sensor. MAF. Either the sensor is faulty or the wiring to it is no good. I'de check that first.
da40
Car: 1995 SE 240sx
check ur iacv valve
mccune240
thanks guys ill check them shortly
and how do u check an iacv
Modified by mccune240 at 1:36 PM 9/24/2006
Modified by mccune240 at 1:38 PM 9/24/2006
