rpm dip really low after ignition?
Kouki_Projekt
Sometimes when i start my car, the rpm drops like really low like down to 100 or sometimes even stall out. ive heard a couple of things what it could be(Tps, bad fuel filter, Maf, Vacuum leak, etc.) and im pretty sure its a simple problem but i wanted to confirm here who have also had the same problem and could clear it up with me.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
all the things you listed could be the issue...its possible your fuel pump is going or the filter is clogged..if its not those..check wires/plugs/coil..id start there..keep us all posted and if its not any of those..then we will point ya in the rite direction.
