nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Sat Apr 11, 2009 1:28 pm
well not to say anything about the builds that some of you have had, but for those who think RP messed their engines up, what makes you think it was RP?
Where you running regular oil first, as you are supposed to with new builds? did you monitor your engines performance?
when i have seen oil mess up a motor, it was not a fast thing. You typically notice something isn't right before it goes, especially if you are monitoring your engine during break in.
Also, I think a lot of people make claims that the stuff is no good (even though it tested better than other synths), but they don't take into account the condition of their motors, the viscosity and weight that they should be using. And also I know a few people in my area who have blown up engines after switching oils, but it can (in most cases) be traced back to a bad build, insufficient oil or cooling, or just plain engine abuse.
I've used RP in all my SR's (7) and never had a problem. I use Zmax every 3 or 4 months as well. That stuff is awesome, especially when you drop a new swap that hasn't run in a while. It cleans it out pretty damn good in my opinion.
