Routine maintenance gone bad...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Ugh...
I decided to do some work on the Q today (she's about 2000 miles from 200k!). Changed the differential fluid, changed the oil, checked other fluids but none needed changing.
Afterward, as I was about to go home (did this all at my parents' place) I decided to check the oil to make sure I filled it properly. Big mistake. I extracted the dipstick...AND THE DIPSTICK TUBE.I CAN NOT get the damn tube back into the oil pan. There's no visibility to find the hole, I can't feel for it because things are too cramped. I tried for probably hours.
It LOOKS like I could find the dipstick tube hole if I remove the A/C compressor. Problem is, I can't get the stupid belt tensioner to work. Seems like clockwise should release tension (lower the pulley) and counter-clockwise should tighten. But neither seem to do anything.
So:
Does anyone have pictures of the engine out of the car that show the dipstick location?And any ideas on the tensioner? I want to try and fix this tomorrow, but at this point I'm at a dead end.
Anyway, I've been dead tired for several hours. I'm going to sleep. Any help would be extremely appreciated.
qship96
Car: 1996 Infiniti Q45
Did you loosen the pully center bolt before trying to adjust the belt tension?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Nope. I did not think to do that. Thanks!
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
also, the thread pitch is backward on the A/C and alt pulleys. It is still 'righty-tighty' for tensioning the belt---but the tensioner will move toward you ratchet as you rotate the bolt CCW to loosen.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Well...I ended up getting the dipstick back in without having to go through the hassle of removing the A/C compressor. I bought one of those telescoping mirrors, and was eventually able to re-seat the tube. Now I just need to find a bolt that fits the hole for the dipstick retainer dealie so this doesn't happen again.
