round 4 fight!! exhaust manifold question
matafied
Car: 1989 240 rb25det 1992 240 rb25det
Well most of you know i have two rb25det powered s13's, well during a saturday drive some idiot decided to brake check me while we were taking off from an intersection. long story short, i no longer am driving my hatch due to front end damage i am now swaping my 4th rb into a trunk car i bought a few months back. well when i removed the motor i did the usual inspection and discovered a few loose exhaust studs that quickly turned to broken exhaust studs lol. i noticed black carbon deposits under the exhaust manni so i removed it to discover four cracks on my manni . i thought these things where bullet proof! has anyone every seen this on their rb exhaust manni before?? and whats funny is i put down 275 rwhp with this thing
a thrashed spec clutch after 3 years of abuse old trashfuture daily
240z4u
Car: '95 Nissan 240SX
If you want another stock manifold let me know, I have one.
Wierd on the cracks! Mine certainly didn't look like that!
Evan
Carl H
im gonna speculate that the reason it cracked was because of thermal expantion and loose studs...
meet07
Car: 89 180sx rb25det
I could have also been running a little lean as well as vibrations( motor mounts and or loose exhaust manifold bolts).
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
I bet carls spot on. I replaced my exhaust studs with arp's for that reason. The factory ones break too easy and there a bastard to get out of alum.
gawdzilla
Car: none
s14 2510’s wrote:I bet carls spot on. I replaced my exhaust studs with arp's for that reason. The factory ones break too easy and there a bastard to get out of alum.
i haven't had a problem *knock on wood* with my factory ones. never changed them out and my manifolds have been on and off probably 6-8 times since I got the motor. are you guys using anti seize? I usually give everything a good coat so the bolts go in and out easier.
