I gotcha on the PAK sound.
The video link works well.
I think you might want to check your timing and see if you can adjust your idle speed after that. Again I guess. You said 15 BTDC, but is it steady or does it bounce around at idle? You should look into how to get codes out of your ECU. Maybe a sensor is not giving proper signal to the computer. Throttle position, Mass Airflow, Cam Angle, and Oxygen are critical sensors. Also, vacuum leak. I don't know how to check everything in vacuum, especially on a turbo car. Maybe by spraying car cleaner around any piping after the MAF. You should look it up. Sounds like you're getting close though.
