Sundalo92 »
https://forums.nicoclub.com/sundalo92-u212424.html
Wed Nov 21, 2012 12:00 pm
Hellow, Sundalo92 here. new to posting but not new to the forums. I own a 93' S13 Hatch w/ KA24DE
I've done my searching and can't find the answer so I decided to create a thread.
Anyways, I initially had an issue where I could not shift into any gears when the vehicle is on, but shifts just fine when its off.
So I ended up replacing my clutch master cylinder, beginning with bench bleeding the CMC and bleeding the system only through the slave cylinder. I bled it real good until the new fluid came out.
Once everything was back together I took the car for a cruise. Everything felt fine and better than before, the clutch felt like it's supposed to and I was able to shift like a champ again.
During the cruise I decided to stop by a friend's house and chill for about an hour and head back home. Just as I was leaving to go home, what I thought I had fixed came back. I was having an extremely difficult time putting my car into gear without grinding them.
What I'm confused on is everything was working GREAT when I installed the new CMC, but now it's back to the problem I'm having before?
Ideas?
Notes:
-Clutch operates normally
-Drove just fine including the clutch and shifting, until I let it sit for an hour
-Slave cylinder seems to be operating normally (I noticed when I had my dad pumping and holding the clutch while I bled the system)
