freakonaleash1187 wrote:Pull your plugs and check them, that is always easy to do. Also, run an ECU diagnosis, that could tell you something. And clean your throttle bodies, dirty throttle bodies can cause hesitation.
Ya I don't want to spend too much on it since its getting swapped anyways, but i definately don't want it to leave me stranded. We're changing the plugs on it soon anyways, so i'll check the tb's at the same time.
Also, i noticed that two of my plug adapters (the part that is recessed into the engine to plug onto the sparkplugs) are missing a green bolt each. Anybody know where I can get replacement bolts? Dealership doesn't have any and can't get any.
