ok well iam not afraid to get technical. i have lots of experience workin on cars. but to test the resistance in the injectors dose the plenum have to be removed or can i reach them with out doin so???Romeo5k wrote:My first guess would be injectors. And thats without getting technical.I suggest before getting technical, running a can of BG44k in half a tank of SUPREME gas! See if that helps any. If it does, Play close attn to it, If it doesnt, get ready to get technical. Its time to Ohm your injectors. All that is somewhere if you use the search field. But before u start like i stated , do simple stuff first.
so your car did not throw a check engine light either ??? cause i was thinkin if it was a miss fire from a coil it would "catch" it and i would be able to pin point it.rkeats wrote:Replace the coils!! I had the exact same thing in my 99Q45t. I finally gave up and got all 8 of them(coils), took me about an hour to replace them all and I am not a mechanic. It has been pointed out many times on this forum that the coils are the answer to the idle miss. It has been sweet running now for over a year. Now on to the rear shocks/struts!!
Lol - I read that in the voice of the little poltergeist girl.bullittandy wrote:You'll see.
Its the coils.
lol iam not doubting you. by the looks of it you have far more experience with these cars then i do.bullittandy wrote:You'll see.
Its the coils.
