edhogan1224 »
https://forums.nicoclub.com/edhogan1224-u245111.html
Tue Dec 09, 2014 5:49 am
Okay so im not that new to cars, but I am pretty new to the Nissan/240 scene. I was driving home from work the other day, trying to merge onto the highway but the car next to me wouldn't let me. I got on it in order to get past him, taking it to redline before shifting. Not pinging off of redlimiter or anything other than driving the car hard. Didn't notice anything until i got to a stoplight, where, once i had stoppped, i noticed that i now had a very rough idle that would jump a few hundred RPM's then back down, jump a few hundred RPM's then back down, etc. Upon pulling away from the stoplight, i noticed that the exhaust was much louder under acceleration. So, i made it home without incident and i opened the hood to see what the damage was. The exhaust leak sounded as if it was coming from forward of the front of the door, but behind the engine block itself. Since my 240 sat for 10+ years before i got it, and still has its original exhaust, I'm guessing that I popped a hole in the exhaust in front of the secondary O2 sensor and the secondary O2 is getting fresh air readings from the hole and causing the car to run funky. Am I right in my assumptions, or is this a more serious issue? Ive read about the sticking fuel injectors and whatnot so i wanted a second opinion. Also, there was no overheating/oil or coolant leaks/etc. that would leave me to believe that the headgasket had blown.
