EdGs »
https://forums.nicoclub.com/edgs-u201906.html
Sat Sep 13, 2014 5:28 pm
Update: Replaced the EGR solenoid and got a slight improvement in the idle, but still very rough and sluggish.
Cleaned the MAF sensor and no change.
Found that the fuel filter was definately restricted. Replaced it and got a small improvement. Still a pretty good miss, but does not stall as easy.
Plugs and wires checked good. Distributor has a bad seal and is leaking oil slightly around the base of the cap, will addresss that later.
Advanced the timing a little and got a big change in reponsiveness, great acceleration and pickup, but still rough idle.
Spayed throttle cleaner around the intake and got a big improvement in idle, so the dreaded intake manifold gasket leak is the main culprit here. 212K miles on the car, so I can't complain much.
I am not looking forward to this repair, but don''t have a choice. Wish me luck.
