GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Thu Dec 19, 2013 3:59 pm
There are a few codes that don't cause the CEL to turn ON, but failing injector coil isn't one of them, though things can be marginal/intermittent for a while. Ohm checking is simple and conclusive.
Coilpacks are pretty reliable and easy to swap around. Maybe a bad or fouled spark plug? Not many people pull the plenum to replace injectors and if one is bad, how about the others (ohm check) if corrosion/age is part of the problem and who knows about reconditioned injector reliability?
