Rough Idle??
PapaCamCam
Car: 96 240sx
car will sometimes idle rough then smooth for a little while then rough again.When i barely press the gas when im movin it runs fine then when i try to give it more gas it sounds like its mis firing.it will alternate between runnin good and runnin like ****
exit7aracing
Car: 1989 240sx coupe
check your plugs and coil packs. i just got over having the same type of problem.
owlznite
Car: '89 240sx Redtop sr20det swapped Fastback. Black, power window/door, FMI, Koyo Radiator, ACT 6-blade
boost leak. check your inter-cooler pipes. mostly likely its that. pressure is so high that even the tightest screw on can sometimes bust. get quality. its worth the money, when you consider your engine is on the line.
