Rough Idle
Nissan 350z / Nissan 370z general community discussion forum
etl45
So i got a small rough idle. Not that big, but still noticable.
i cant figure out what is causing this?
my intake connecttions and plugs are all secure.i have reset my ecu and done relearns on everything.
what else could i do?
thanks.
Anthonysflying
Car: 2004 Silverstone 350z Touring
I had a really mild rough idle...the problem went away after i changed my spark plugs. oops
Note: i recommend giving your air filter a good cleaning(or replacement) too.
etl45
well i just cleaned my air filter.. i have a CAI.
spark plugs? hmm.. maybe i should replace them?
my car only has 17,000 miles on it. BUT its a 2004. should i go ahead and replace them?
thanks
raremotive
Car: 04 Infiniti G35
not a bad idea, get yourself a nice set of NGKs.
zozoka1212
Car: 08 Infiniti G35x
etl45 wrote:well i just cleaned my air filter.. i have a CAI.
thanks
That could be one of the reason why. If you just cleaned your intake and oiled it. Maybe the maf got dirty from the oil.
zozo
etl45
nono.. i just cleaned it because of the idle.
etl45
help my please! i changed spark plugs and cleaned my MAF!
still there...
ahhhhhhhhhhhhhhhhhhhhh
i cahnged to ngk iridiums..
help!
R350Zz33
Car: 2008 350z enthusiast
do u still have your warranty ? if so put you stock intake back on and take it to nissan they can reset the idle
etl45
accualy i dont have warrenty. but i did find a diy on how to relearn your idle, so accually reset it myself!
thanks for the help guys! keep it coming!
i posted the samething in another 350z forum.. they all seem to be really not helpful. but this forums seems great so far! haha
zozoka1212
I still think it is your maf. Try to unplug it when it is running to see what it does. It also can be vacum problem. If you have vacum leak or maybe your o2 sensor. I'd try to unplug the maf while it is running.
zozo
R350Zz33
was this my350.com lol
raremotive
Ever tried checking out the Idle Air Control Unit?
Modified by Rare_f8 at 8:47 PM 1/24/2009
etl45
yes it was my350z forum haha
and idle control unit? do you mean reseting it so it learns?
or physically checking it out? and if so.. how ?
thanks
JETPILOT
Your unstable idle is normal. Nothing you can do about it. Putting in new plugs or cleaning your MAF sensor won't help. You would be getting a check engine light for a cylinder misfire, or a MAF voltage issue. If you have no check engine light then everything is fine. You can't diagnose these cars by taking a guess. That's what the computer is for.
etl45
ahhh that sucks.. i guess i have to take it into the stealership~
Return to “350z / 370z Discussion”
